1988 Chevy Suburban r12-r134a retrofit problems
Posted: Tue Aug 17, 2021 4:08 pm
High everyone. I've been gleaning knowledge from this site for a while, but this is my first post.
I have a 88 Chevy suburban that needed a new compressor and it was recommended to be retrofitted to use R134a at the same time. The mechanic said he had done quite a few retrofits and while they do not cool quite as well as R12 his customers who he had done them for were happy, so I had him do the conversion. It seemed to work ok , but after about 5000 it developed a leak and stopped working.The shop that did the conversion is now out of business so since I have an R134A gauge set, vacuum pump, electronic leak detector and a little knowledge about automotive A/C systems I decided to try to fix it myself.
I vacuumed the system for 1 hour then put enough r134a in to get the compressor to run. I then used the electronic leak detector and found that the evaporator had a leak. I replaced the evaporator, orifice tube, accumulator/dryer with OEM replacement parts and added a high pressure cut off switch to the compressor. I also upgraded the condenser from the stock tube and fin type to a 3/4 x 16 x 26 parallel flow 2 pass unit made by UPI. I was thinking that increasing the efficiency of the condenser may help make the system produce cooler air. I removed the compressor and drained out the residual oil. I added POE oil to the new components for a total of 6 oz. I then evacuated the system for an hour. Since the condenser is not stock I figured the recommended amount of refrigerant for this retrofit would not be correct so I charged it up until the compressor stopped cycling at idle and the pressures were at 27 and 175. The air temp coming out of the main duct was around 58*F with the ambient temp 90*F . I took it for a test drive to see if it would improve but the compressor started cycling every 2 second or so and the temp only dropped about 2 degrees. I've tried adding more refrigerant until the pressures were 34 psi and 210 psi @650 RPM and 21 psi and 250 psi @ 2300 rpm, ambient temp 90*F.
I may be mistaken but it seems like the compressor should not be cycling this quickly when driving. I am wondering if the orifice tube should have been changed to a different size or an adjustable type. I have built a custom R134A system that used an expansion valve for a military HUMVEE that worked great but this retrofit has me in over my head.
I could really use some tips or wisdom to get this system working properly.
Thanks in advance for any help with this trouble shooting.
Luther4130
Luther4130
