1997 Jeep Wrangler TJ High Side Pressure
Posted: Sun Aug 15, 2021 7:18 pm
Hello,
I have a somewhat unusual situation. My TJ 4.0L came with no AC but I checked out the situation and the wiring harness and engine accessory mounts are the same with/without AC so I bought every piece to install the system. All parts came from online retailers with reasonable reputations but low prices i.e. not exactly OEM quality. The compressor is a copy of SL7H15. I have good AC experience and have a vacuum pump, recovery system, gauge set, scale, valve tools, etc., and have done several repair jobs with good success.
So I installed everything, added 8 oz of PAG 46 (compressor was empty but came with oil in a bottle), and evacuated the system. The first time it didn't hold and I found a torn o-ring. The second time it held vacuum so I charged with 20 oz of R134a. The compressor cycled as I added refrigerant and stopped cycling as I approached the 20 oz charge. Everything seems in order except that the vent temperature was only 55F.
With the correct charge at 75F ambient, engine at 1500 RPM, the low side is 34 PSI and the high side is 325 PSI. By my understanding, this is very high on the high side.
So I am thinking restriction. The orifice tube is in the "liquid line" about 12 inches after the condenser and is not removable from the assemly. The line is very cold after the orifice tube but that could be normal. I wanted to consult with the experts before taking action. Again, every part is brand new but could possibly have quality issues.
The system has been working this way for a few weeks and is much better than nothing but I know it can be colder. The Jeep has only been driven once with the new AC.
Thoughts? More information needed?
