How cool should be vehicle ac be running?
Posted: Tue Jul 27, 2021 7:30 am
by Tsuper
It’s 90 degrees out with high humidity in Florida, vent is blowing 62-65 with a stick thermometer down the vent
Re: How cool should be vehicle ac be running?
Posted: Tue Jul 27, 2021 7:51 am
typically we try to get/see vent temps of 45 or so degrees.
Suggest you get your system checked at a pro AC shop
Uncle Tabasco's we grease'em corner shop not such a good idea
BTW you did not provide make/model/yr
Posted: Tue Jul 27, 2021 7:58 am
by Tsuper
2014 F250 diesel. Just recently had the evap core and compressor replaced, blew cold in the low 40s for the first week.
Posted: Tue Jul 27, 2021 8:20 am
What issues were you having with the compressor and evaporator?
Posted: Tue Jul 27, 2021 8:22 am
by Tsuper
Evap was leaking, and the compressor was shot
Posted: Tue Jul 27, 2021 8:31 am
I'd be tempted to bring it back....may still have a leak......
Posted: Tue Jul 27, 2021 11:48 am
Tsuper wrote: Tue Jul 27, 2021 7:30 am It’s 90 degrees out with high humidity in Florida, vent is blowing 62-65 with a stick thermometer down the vent
That sucks !!! Should be in the 40s Fahrenheit.
Tsuper wrote: Tue Jul 27, 2021 7:58 am Just recently had the evap core and compressor replaced, blew cold in the low 40s for the first week.
Ya gots a leak !!! Take it back to the shop, it worked fine before refrigerant leaked out !
Posted: Tue Jul 27, 2021 12:54 pm
Cusser, good to see you on here more often, I always enjoy your posts,
Dave
Posted: Tue Jul 27, 2021 2:17 pm
If it worked well for a week and then it didn't, I agree that your A/C system probably has a leak or leaks...someplace. The trick is to find it (them) by having the shop check every part--including the new components--using a "sniffer."
Although buried deep inside the dash, checking the evaporator by "sniffing" the condensate drain tube often results in a "hit" if the evaporator is leaking. A compressor can leak at the shaft seal, case joints, control valve if applicable, and/or hose connections. So I would pay particular attention to those areas even though the compressor is new.
How does the condenser look? Any suspicious oil stains that might indicate refrigerant leakage? The condenser can take a real beating from road debris because of its location at the front of the vehicle, and they often leak due to damage and/or corrosion.
Any refrigerant tubing down low that might be subject to corrosion due to chemicals applied to icy roads in winter?
Posted: Tue Jul 27, 2021 6:07 pm
Yeah, I vote leak.
Given the average price of that job, I would take it right back.
