1986 C10 not holding Vacuum
Posted: Fri Jul 16, 2021 2:36 pm
First time to post but very glad to have found this forum.
I have a 1986 C10 that I am trying to get the original AC system working. It worked 3 to 4 years ago but someone took the evaporator out. I have flushed all of the lines and replaced the Evaproator and Dryer. After replacing all of the o-rings i hooked everyhting up and it held a vacuum. then the compressor did not work (I did not replace). Replaced Compressor but now I cannot get it to hold a vacuum. I used the metal washers with rubber seal that came with the compressor.
My question is any advice on how to see where the leak is without haveing refirigerant in the system? I have heard of using compressed air and listening. I am replacing all of the o-Rings agian to see if that helps.
thank you
Bryan
thank you
Bryan
