Is Recovery Necessary for DIYer, on a limited basis
Posted: Tue Jul 13, 2021 9:42 am
Hello,
I am working on the A/C for my 2009 Ranger because of, what else, low cooling. It seems to have correct pressures on the A/C manifold I bought, but the A/C/ clutch constantly cycles. I added Freon, which seemed to lesson the cycling, but the cycling did persist abnormally, and the cooling is a tad better, but not great, as before. My question is should I invest in a $500 recovery set up to remove the freon before pulling a vacuum. I know it's EPA not to vent refrigerant into the atmosphere, and I respect that, but is the investment worth it and common for the DIYer, or do most people just let it flow to the atmosphere. I don't really mind the investment if it's that critical, but if it's something most people pass on, would like to know that too. I also have a 2005 Impala doing diddly, and a home A/C I would like to be able to service if necessary. Guidance and advice is kindly appreciated, and thanks in advance.
