Compressor,TXV, or Scroll valve
Posted: Mon Jun 21, 2021 10:47 am
Bought a used 2006 Ford Freestyle last winter from private one owner. I have cool air on highway with warm air in town. Previous owner had aftermarket compressor put on in 2013 and said it began acting up last summer. He had dye test and pressures checked and they added a small amount of refrigerant. No leaks. I just had a AC tech check the pressures. I saw readings. Ambient temp was 85 F with car warmed up and running. At 750 rpm idle with the AC set at 60 F on both driver and passenger side controls(it has dual controls) with fans blowing on high the low pressure side reading was 52 and high side was 100. Both abnormal.
At 2,100 rpm on interstate the air coming out of driver side front ducts was 72 degrees, passenger front ducts and rear ducts 82 degrees. After exiting highway and pulling over within 2-3 minutes at idle of 750 rpm duct air temp on driver was 82 and on the passenger and rear ducts it was 89 degrees.
I can hear compressor cycling. condenser coils are clean. I checked suction line and it was warmer than high side line coming out of compressor that goes to drier. Drier is same temp as high side line and normal to touch. If I increase temp settings to heater the fans blow hot air which makes me believe the blend actuator and door is ok. I believe it is either the scroll valve, the expansion valve, or the compressor as I have read that the drivers side vents are provided cold air before the passenger and rear vents. I can replace TXV and scroll valve much cheaper than the compressor as labor costs getting it off and on are pretty expensive due to its location Any thoughts as where to start will be appreciated.
