2017 F150 AC problem.
Posted: Mon Jun 07, 2021 3:40 pm
My fiancé and I were coming back from vacation yesterday and turned on the AC in her truck. The AC came on normal and it was very cold. We had it on max.
About five minutes later we heard what sounded like a moaning sound that only lasted a few seconds. We didn't know if it was our vehicle or one that was driving around us. AC was still cold. About five minutes later we heard the sound again for a few seconds and right after that noticed that the AC started cooling off until it was barely cool.
We stopped at a rest stop and I looked at the compressor and noticed that the clutch was not turning and that there was black rubbery looking stuff sprayed on components surrounding the compressor and sticking out of the perimeter of the clutch. I figured that the clutch had let go.
Today I checked to see if the clutch would still turn and I can turn it easily so I don't think the compressor is locked up. Am I on the right path with this guess or could the compressor still be damaged? Could the AC charge have leaked out if the clutch let go? I don't have any gauges that will work on the fittings on this system to see if I still have a charge.
My question is this if anyone knows, can the clutch on this compressor be replaced without discharging the AC system? The Ford dealer says no but someone on another forum says yes. This truck has the new 1234yf refrigerant and I'm not at all familiar with this new stuff or the system.
I have not found any shop that will attempt to fix this truck because of the new refrigerant other than the Ford dealer. I did find one guy that said he would look at it and if it looks like he can replace the clutch without evacuating or recharging the system, he would replace the clutch for us. This guy is an ex-Ford tech that went out on his own and opened up his own shop but is not currently setup to evacuate or recharge these new systems.
I would appreciate any advice. It looks like our options are pretty limited for getting this fixed. Thanks.
PS. Truck has the 5.0L V8.
