Topping off R134a - how to?
Posted: Thu May 27, 2021 8:36 am
Happy Thursday everyone, I used the search function but did not find anything conclusive.
I realized I am a bit low on the refer charge and thus I want to add more R134a in. Probably need to use hot water and take my time to get in more refrigerant as vapor via low side. Since the system is now closed, what is the best way to go about hooking back up the couplers and purging the lines?
If my thought process is correct, please let me know:
1.) engine is off and manifold controls CLOSED
2.) hook up quick couplers to low and high ports which will give you pressure readings
3.) turn on engine
4.) hook up central/service line to R134a bottle and purge at manifold connection
5.) purge low-side and hi-side lines by unscrewing momentarily at manifold to allow R134a to fizz out
6.) now add R134a to desired spec ONLY to low side. Close low-side manifold valve.
7.) remove the low side when its running then remove the high side with the engine off, it gives the lowest pressures in the lines.
3.) turn on engine
