Oil in an RV engine AC compressor
Posted: Thu Jul 14, 2016 7:33 pm
1999 Chevrolet P30 chassis (as far as I can tell), with a 7.4L engine, who knows what evaporator, and a giant old-fashioned tube and fin condenser. I've noticed that the compressor is mounted much higher than any other part of the AC system, if it matters.
Replaced the compressor because the belt that was on there (and indicated by every parts-house lookup) was .5" too short and it ate the compressor pulley bearing up (will try and post pics).
(Stupid photobucket won't let me copy links via iPad)
I've rotated the compressor hub quite a bit trying to get oil out of it so I could measure and replace the same amount, but all I get out is maybe a teaspoon full, even after leaving it propped up for a couple days.
Any guidelines on how much oil I should add?
