Options to fix this compressor, 2001 Honda Insight?
Posted: Mon Apr 19, 2021 4:14 pm
by atikovi
Already got the remains of the field coil off. Compressor shaft turns fine and there appears to be a full charge in the system with no signs of leaks. I don't see a clutch assembly sold for this model outside the dealer whose prices wouldn't make sense. Other than picking one off my parts car or buying a complete new aftermarket compressor, are there any other choices?
Re: Options to fix this compressor, 2001 Honda Insight?
Posted: Tue Apr 20, 2021 6:09 am
I think I'd also lean towards brand-new compressor. But since you have used parts available, and the compressor shaft turns and you say it appears to contain your R134a, you're not out much to try your used parts.
Posted: Tue Apr 20, 2021 7:56 am
New OEM just a few dollars more than the import version.
https://ackits.net/product/14-0201nc/
Posted: Tue Apr 20, 2021 2:06 pm
by atikovi
I bought the car to sell so spending that much for a new one if this one turns out bad, would be a last resort.
Got the compressor off my parts car. Clutch works fine. Will swap it out tonight.
