AC working, but vent air still not cold
Posted: Thu Apr 15, 2021 2:17 pm
Hello Auto AC forum,
It seems quite certain that the ac system is working in my 2013 Impala.
I am getting a water puddle on my driveway when the ac is left on, but NOT when it is left off.
The light on the knob (under the snowflake image) will go on and remain on.
I can see the compressor clutch is turning.
Fluid pressure is about 30 psi on low side when compressor is engaged.
However, the air coming out of the vent inside the car remains same as ambient temperature (about 90 deg F).
When I put the temperature selection to a higher temp, the air from the vent DOES get much hotter, so I know the temperature blend door is working.
Any input or ideas would be greatly appreciated.
