Jeep Cherokee XJ A/C rebuild
Posted: Thu Apr 08, 2021 12:49 pm
Hi,
I'm new here, so thanks for the add. I have a 2001 Jeep Cherokee XJ. The A/C didn't work when I got it in 2014. A check revealed no freon and a bad compressor clutch. I replaced the clutch and threw in a can of that A/C stop leak stuff and some PAG oil (the AC had probably been inop for years) and lo and behold, it blew nice and cold. I've been nursing it along by adding freon every summer, but last summer it started leaking the charge out in a matter of days. This year, I decided to fix it right, so I have a brand new OEM compressor, condenser, hoses, orfice tube, and drier. Everything but the evaporator, which is buried in the dash. I'm going to test it and find the leak before I take anything apart to verify that it's not the evaporator. If it is, I'll have to pull out the dash and replace it.
Here's my question: If the evaporator is NOT the source of the leak, is there a way to flush it clean so the new components won't be contaminated with the old oil and leak sealer stuff that's in there? Thanks for any advice.
