I have stuff in my refrigerant. Now what?
Posted: Thu Dec 17, 2020 12:35 pm
I have a '96 Geo Tracker. It is a black convertible with a single layer top. It gets hot inside. I recently replaced the compressor because it leaked.I did add 2 1/2 oz of pag. The specs call for 3 1/2 but I know there is some left in the system. I also replaced the high side hose from the compressor because it leaked. I no longer have to add refrigerant. Right now I am on the Florida keys. Today it is 80f and the air going into the system (on recirculate) is 90f. The air coming out of the vents can be as low as 61f but not so low when stopped or at lower speeds. The low side reads 30psi. If it gets higher it will cycle. It gets the car temp down to 80 but it is dry and blowing so it seems OK. I don't think it will be so good at 90f though.
Because it was open to air while replacing the compressor and pipe I plan to replace the dryer, draw a vacuum and refill with the correct 24oz by weight. What I don't know is what lurks in the system and how it will effect the end result. Over time I have added refrigerant often as well as an additional 2 oz of PAG out of fear of wrecking the compressor. I once used 3 oz of a 7 oz can of stop leak too. Will having the system emptied remove any of that? Is there a simple way to clear it out? Is absolutely necessarily necessary to flush it? A pro will want more than the car is worth. Can I just pull the vacuum, hope the PAG is close and fill it? What are my chances.
Should I replace the expansion valve? Some say to do it routinely. It requires the removal of the evaporator.
