AC has a loud short bang at startup then cools normally
Posted: Wed Sep 30, 2020 12:25 pm
96 328i sedan Air Conditioner has loud bang at startup, then cools very well.
My AC wasn't cooling too well so i had a neighborhood shop do a recharge.
Afterward recharge, was told low and high pressure gauges looked good, system blew quite cold BUT a very loud bang when I start the AC. I don't even start the AC while driving right now. I leave it on and only comes on when cranking the car. Much quieter noise during engine and ac startup at the same time.
Mechanic troubleshot then replaced compressor and accumulator. After he pulled a vacuum and recharged, had warm air. Gauges looked normal. Turned out he put 2/3 air and 1/3 freon for the recharge. Told me the gauge set he had was bad. He then took it to another shop and ran a vacuum on it and refilled freon by weight. AC is blowing cold again BUT the loud bang at startup is still there. Hi and lo gauges read normal range.
Any ideas what could be causing this loud bang at startup?
Could it have been overcharged both times and this is the culprit?
Is there a high pressure relief valve on the compressor that is releasing?
Could air still be in the system causing this?
Could the accumulator have gotten messed up? First time on the initial charge when the bang started; and then the NEW accumulator being messed up after install because he recharged the system with faulty equipment.
Should i have another vacuum and recharge done by weight hoping this eliminates the bang at start up.
Gus in Vegas
USN retired
Gus in Vegas
USN retired
