100 psi on low end and compressor clutch not engaging
Posted: Sun Apr 09, 2017 7:40 pm
Compressor went out on my 07 Chevy silverado. I installed a new compressor, new accumulator, and new orifice tube. Ran a vacum for awhile then shut off to check for leaks, good to go. First 12 oz can of 134a sucked right in. The second can however only got about half in before it stopped sucking.
Watching my gauges closely it looks like the ac clutch is not kicking on until it gets to about 100-110 psi and then cuts off at 90 psi. It is making it virtually impossible to put in more refrigerant.... but I probably dont want to keep putting in refrigerant if my ac clitch isnt kicking on until that high of pressure?
Any ideas? I thought it was my new low pressure switch that I installed on the new accumulator but I uninstalled it and reinstalled the old switch by nothing.
