2008 F350 specs
Posted: Mon Aug 17, 2020 7:12 am
Hello and thank you for the platform here to ask questions
2008 F350 quad cab XLT lariat
The basics......
Removed cab to replace high-pressure fuel dist everything original had this truck since brand new
System was perfect before so I am trying to get it back there again but I did put new parts in the a/c system while it was apart along with all o rings and "seals" the flat aluminum style
New receiver dryer
New condenser
New motorcraft compressor
New orifice tube (in the correct direction)
Did not flush the system it was clean and no sparkles
Blocked off all open lines while storing for cleanliness
Re installed everything
Added as close to 6oz of oil as I could measure
Pumped down to 28 held for 45 min no prob
Let vac run for about another 30 min
Here is where I keep getting misinformation
Truck sticker says 27oz
The crazy internet is all over the place with some saying 37-42oz !?!?
Got two cans of 134a at Wally 14oz cans for a supposed total of 28oz
Opened low side it took the first can no prob took about what seemed 2 min and a few cycles
Lost just a small burst from the second can when changing the silly new blue non puncture adapter but nothing huge
Truck took second can quite faster in what seemed one or two long cycles
It sweats and gets "cool" but not like she used to
No official mechanic but nobody works on my stuff but me unless it's on the machine shop level
Electric contractor by trade Truck nut by birth so I don't know what these numbers should be at
Compressor engaged
High side 250ish
Low side 45ish
I hope this is a simple fix truck has ran no more than 2 miles or 25 min since the charge was shot to it
Any help would be greatly appreciated if advance
The basics......
New receiver dryer
New condenser
Compressor engaged
High side 250ish
Low side 45ish
