Want my 1956 Imperial to be a freezer in the summer
Posted: Sun Jul 26, 2020 6:16 pm
First post here.
I have a project that I want to do, and I am doing the research to make it happen.
I have a 1956 4dr Imperial that I am putting onto a 1994 Dodge 2500 4x4 chassis with a 12V Cummins to use for some offroading. I live a bit outside of Fabulous Las Vegas NV where it gets very hot during the summer - it was 122F recently. In my other cars I have measured interior temps of 168F and dash temps of 225F+ when the sunscreen was not up. So not only is the air hot, but everything else is too, and takes quite a bit to cool it all down. My 98 Saturn wagon struggled during the summer. The Craptastic 07 Nissan Versa was blowing 34F at the vent after I serviced it when I first bought it. I believe it is the first car I have had here where I could back the fan down from maximum. The usual AC setting here is on maximum for 6 months. Unfortunately, the AC was the only thing that was good on that car.....don't buy a first gen Versa, dead at 128k. Both the Saturn and Nissan are 134a systems, so I know it will get cold enough as long as the system is set up right. As it was explained to me the Saturn struggled because it was 134a in a system sized for R12. GM did not know how well they would sell when first launched, so minimal effort was put into the HVAC system. The later ION AC is excellent.
So, with the 56 Imperial I will have a huge internal volume to cool, much larger than the single cab donor truck. The car has the optional factory Chrysler Airtemp AC evap in the trunk, and I am thinking about incorporating it into the new system. This is going to be a build, so I plan on running some new vents where I want them; feet and seats for starters. I hate being cool in front and still sweating against the seat. Has anyone done a dual compressor set up? Run both for rapid cool down, then cut one once it is cooled. So, instead of twin turbos, twin AC. It would also offer some redundancy if one goes, there is a backup. How well will the trunk evap work with 134a? Obviously I am also looking to put some high volume fans in as well to keep the extra vents pushing cold air. Another peeve of mine is when I switch to both feet and face the air volume drops a lot. From what I have read the standard car AC is anywhere from 3 to 7 ton capacity, and I want a lot more. Is it doable, or should I just install a ThermoKing reefer unit on the roof?
