compressor connector
Posted: Sun Jul 12, 2020 6:04 am
				People,
2001 civic ex, got the new compressor, car taken apart and found out the new comp connector has 2 black and one red wire, and the connector is different. My original one has only one wire and went directly to the thermal protector. Can I cut off the connector and somehow make it work? I guess the one wire from the old comp is hot. But the thermal protector on the new comp has 2 black wires going to the connector end. The old comp has the thermal [protector in line, so can I simply cut off the 2 black wires and send one to the coil and wires it as the old comp IN SERIES as opposed to parallel?
Thanks.
Thanks.
