99 Maxima poor cooling *SOLVED*
Posted: Sat Jul 11, 2020 11:57 am
Basic info:
1999 Nissan Maxima
Low temp: 70 - 75 (1500 RPM)
high side 180 - 200 (1500 RPM)
All of a sudden my A/C stopped cooling very well. The temp in the car would fluctuate from 50 to 80 degrees. Tested the pressures and low side was around 50 and high side was around 150. I replaced the Refrigerant control valve (RCV) on the A/C compressor and the expansion valve. I heard fluctuating temps like this could possibly be due to the RCV in the compressor. Well this seemed to help for a while. Temp would get down to about 48 and wouldn't jump around like it had before from 50 to 80. This didn't last long though and pretty soon my temps were a constant 60 coming from the vents. Now the pressures were about 60 to 70 on the low side and 170 for the high side. I had put in UV dye previously and there were no signs of any leaks near the evaporator behind the dash or anywhere in the engine bay. At this point I decided to replace the compressor.
New compressor in and same thing is happening. Pressures are around 70 - 75 on the low and around 200 for the high side when the engine is at 1500 RPM. Looking for some advise on what else may be causing the problem? I think i've ruled out compressor since i'm having the same issue with this new compressor. I'm leaning towards the TXV but that was replaced when i did the control valve but maybe I got a dud?
One other thing, when the cooling stopped working correctly I get kind of a musty smell from the A/C. Not terrible but definitely doesn't smell like it should with a properly working A/C. Not sure if that would help with diagnosis at all. Also, when I recharge I do pull a vacuum before filling by weight. Car takes about 23 oz so I just put 2 cans in which should be just about right (and it has been in the past when I had a faulty compressor a long time ago).
Hope someone can help with the next step in figuring out the issue as this phoenix heat is a killer! Thanks!
**SOLVED**
Ended up replacing the TXV since I would be able to check the blend door at the same time to see if heat was mixing in. Blend door was closing fine blocking off any air from going through the heater core. New TXV and I could tell right away when adding refrigerant it was looking better. This time the low side would drop to about 35 to 40 whereas before it was in the 60 to 70 range with the first can. After adding the 24 ounces the low side was around 40 and high side was 225 which are much better pressures than before and the vent temp would get down to 45 - 50 degress (albeit it does take it awhile but that could be due to the 110 degree weather). Drove it around and seems to stay in that 45 to 50 degree range which i'm totally fine with. Not as cold as some vehicles but I think that is about right for this vehicle if I remember correctly.
Thanks for all the help everyone!
1999 Nissan Maxima
**SOLVED**
