1983 Toyota Celica Supra, converted to 134a
Posted: Sat Jun 13, 2020 9:49 am
I have read a few posts here and can't seem to find one that is similar to my situation.
1983 Toyota Celica Supra, converted to 134a.
Recently got my A/C system up and running after many years sitting with no refrigerant in the system. Replaced all the o-rings. Noticed some gunk on the connections and inside the pipes. I cleaned them as best I could though I don't think I got all of the gunk off. Condenser is stock and meant for R-12. Compressor is for R134a after I swapped out the engine. Evaporator, dryer, EPR, expansion valve and all soft lines are new.
Vacuumed the system and it held vac over a multi day period. Held 90psi of pressure for a couple of days as well.
Charged the system with 24oz of 134a. Conversion chart of R12 (26oz) to R134a said I should only use 18-20oz of R134a.
When I charged close to 18oz the high side never really got above 175psi @65F or so and I decided to charge more until the high side reached closer to 250 @65F and that was when the charge bottle was empty. Also, when initially charging the system it took a few minutes, ~3min, to build any sort of pressure on the high side.
Now my current situation is:
Air out the vents is only slightly cool with fan speed on hi.
Ambient Temp~65F
With system off static press is about 55psi
System on engine idling at ~700rpm:
Low side pretty steady at 45-50psi
High side fan off will climb to ~250psi before the trinary switch kicks the fan on (Drier/HP side lines/condenser are hot to the touch) The pressure will steadily drop and the trinary switch kicks the fan off ~175psi (Drier/HP side lines/condenser are hot to the touch) and climb again to ~250psi. This is with only a 10" pusher fan. When my radiator fans (2 - 11" SPAL puller fans) kick on the pressure will drop down to equalize with the low side pressure (Drier/HP side lines/condenser are just warm to the touch). When the dual fans kick off it takes a few seconds (~10 to 20 sec) for the pressure to start to climb and start the whole cycle again as pressure climbs back to ~250psi when the condenser fan kicks on. Radiator fans cycle less frequently than condenser fan.
When the high side has pressure there is a large temperature difference at the evaporator lines. Low side is cold and high side is hot. This is the same at the compressor. Didn't feel the lines with the hi side at the lower pressure value.
Though all of my searching I cannot find anything that is related. The static pressure indicates proper pressure. The inability of to build pressure indicates a worn/bad compressor but since it still builds pressure it should be ok.
Any thoughts as to what the issue may be?
Using the typical charge charts they say Hi Side pressure should be such and such. Is this with the fan running or not?
Is the high side pressure fluctuation normal?
Does oil need to be added each time the system is placed under a vacuum? I put in 30oz (oops, meant 30cc) of PAG46 oil when I first charged it after holding a vacuum for a couple of days. 20cc were because of a new dryer.
Thank you.
Ambient Temp~65F
Thank you.
