First Post!! Help
Posted: Fri May 22, 2020 2:36 pm
Hi! This my first post and I need help so Thanks in advance!!
I have a 2005 BMW X5 4.8iS. It has 95000 miles and is well maintained. The problem I'm having is my AC does not immediately cool after the car has sat overnight. I live in AZ so instantaneous AC is a must!!
In general what happens is the car is started cold the AC will not blow cold until the engine is to temp and has been revved to over 3500 rpms. Then the air blows great and will continue to blow great for the rest of the day even if its stopped, left to cool off and then restarted.
Here the typical scenario:
Outside temp 82 degF
Gauges hooked up Low 105 psi and High 105 psi
Start cold engine, let run/idle for a few seconds, flip on AC
Compressor is engaged
No change in pressures L 105 psi and High 105 psi
Interior fan running at 1/2 speed, vent temp 90degF
Electric radiator fan not running
Let car continue to run/idle, monitoring pressures, compressor engagement and radiator fan
Engine temp at 1/4 on the dash gauge
Engine temp at 1/2 on the dash gauge (typical running temp)
No change in pressures Low 105 psi and High 105 psi
Electric radiator not running
Quik rev engine to just over 3500 rpm then return to idle
Pressures change Low 40 psi and High 250 psi
Interior fan running at 1/2 speed, vent temp 45degF
Electric radiator running
Engine idles for about 5 min and everything stays constant
Rev and hold engine to just over 2500 rpm
Pressures change Low 30 psi and High 300 psi
Interior fan running at 1/2 speed, vent temp 40degF
Return engine to idles for about 5 min and everything stays constant
If the quik rev to 3500rpms is done the engine temp is greater than 1/4 it typically wont have an effect. Engine temp needs to be at 1/2 position.
So once it kicks in it works great, it's the delay in startup that has me stumped!!
Any help would be greatly appreciated!!
Bill
Bill
