1988 corvette, don't understand what it's doing?
Posted: Wed May 13, 2020 3:10 pm
I bought an 88 Corvette convertible last year for the missus and I in our retirement. There were a few things wrong with it so we got it at a good price. All the problems were things I could handle without need for a shop. or so I thought......
One of those things was the AC. The system was flat and I found it was the o ring seals on the Denso 10pa20c compressor were leaking.
I pulled the compressor apart and did new o rings. Saved the oil and put it back in on assembly. Changed out the orifice, which was black with contaminants. I didn't change the accumulator (which might be coming back to bite me).
Put the system back together and pulled a vacuum on it. Let it sit overnight and it didn't loose any vacuum. Then I run the vac pump for just over two hours, to make sure it was as dry as possible.
So I charged the system. I live in Canada, so getting any refrigerant like r12 or 134a isn't going to happen unless you have a very specific (and expensive) license. I've been out of the trade for decades (left the automotive world and went into aviation), so that's not going to happen. As a result, I have to use retail available stuff. I'm using redtek R12a, which is mostly hydrocarbon. Lets not get hung up on the hydrocarbon thing, I'm ok with it and have no other choice right now, except taking it to a shop.I've used it before without issues in cooling performance.
With the car running, it showed just under 50 psi on the low side and it would go as high as 400 on the high side. the high side never drops below 200, even when the car is off. That sounds like a clog or blockage to me, but I can't imagine where.
The compressor runs steady, like it should. There's no cold in the cabin whatsoever. After it runs for a couple minutes like that, the clutch will cycle off, the pressure will build on the low side and it will kick on again. It's not short cycling, but it seems like it's hitting a high pressure limit and kicking off the clutch.
The high line gets hot to the touch (almost too hot) and the low line will start to get cold when the clutch kicks on, but a few seconds in the low line will stop getting cold stop and return to (feels like) room temperature. It never frosts. The high line stays freaking hot the whole time the comp is running.
The really crappy thing is the car was bought used, so I don't know what else might have been jacked with or how long it was left in a low/discharged state.
Pretty sure I reassembled the compressor correctly. I only had the ends off to replace the rubber seals (and the shaft carbon seal). I suppose it is possible I got one of the reed plates in wrong, but IIRC from when it was apart, they're pretty much idiot proofed with the dowel pin locations.
What's going on here? I don't understand why it's not cooling? Could the dryer/receiver be contaminating the system with water and freezing up?
You might ask why do I need ac on a 'vert. My wife is very fair skinned and after a certain amount of time in the sun, I need to put the top up to give her some shade. When that happens, AC is needed to keep the interior cool. C4 corvettes aren't exactly known for not having an engine heated cabin. Top up = AC on......
Here's a quick pic of the ol' wreck if anyone is interested:
