Re: Evaporator fin density and differing TXV adjustments
Posted: Mon May 04, 2020 5:49 am
Superheat is not used in MACV because the compressor does not spin at the constant speeds. The TXV's are different according to how much refrigerant is required to load each evaporator. Smaller capacity evaps call for less refrigerant than larger evaps but you will see less capacity in smaller evaps. Smaller loads require less capacity. TVX's have preset superheat. That is why it is important to weigh the charge into a system. You want to achieve a full column of refrigerant to feed the TXV. This is how I was taught a billion years ago.
