Must I "zero out" manifold gauge set before checking pressure?
Posted: Mon Apr 06, 2020 7:14 am
I have a manifold gauge set that I used to charge an empty system by weight to factory spec with a refrigerant scale. The manifold gauge set still has some refrigerant/gas in it as I just closed the valves off and hung it up when I was done.
So, do I need to vent/empty the manifold gauge set before checking pressures on this or a different car?
Does the manifold gauge set need to be reading all zeroes anytime I go to check pressure on something going forward?
