pressure spiking at startup then nomalizing
Posted: Fri Mar 17, 2017 11:20 am
I have a 93 4runner 3.0 auto 4x4. I just replaced the compressor. evaporator (134a) and matching TXV, and flushed the whole system, system was clean and was running before change with a r12 evap and TXV, but had a front seal oil leak the reason for the new comp. The system is charged with 8 oz. of ester oil, and charged the system by weight. The final pressures came out at 42 low side, 225 high side @ 85 ambient.
The system was running perfect at 40 degrees duct temp for 600 miles. Now it seems at start up the compressor comes on and runs for about 1 minute then the high and low side suddenly spike to the point the high pressure switch cuts the system off. As the pressure equalizes the clutch turns back on and the clutch squawks for a second or two and then quiets down and the system runs perfect again until the car is shut off.
I am at witts end with this. The compressor manufacture thinks it is a condenser clog, but I feel it would not cool if that were the case. I am thinking TXV malfunction or bad clutch magnet. The 93 and 95 condensers are the same units.
Any ideas on this out there?
