Leaking aeroquip fittings??
Posted: Sun Jan 26, 2020 9:27 am
Hi all,
About 3 years back I redid the AC on my '74 Porsche 914. Flushed everything, new compressor and other bits, redid all of the hoses and fittings with aeroquip components. Held vacuum great for over a month. Blows ice cold. Kept it as R12.
Fast forward approx 3 years later, not blowing cold. Needed about a pound of R12 to get back to specified pressures. Again, ice cold. Now the question is, "where is it leaking from".
I ran sniffer along system and discovered that if I get right on top of the fittings, where they meet end of hose, that I get some beeping. Unfortunately, not just one connector but multiple. They are all assembled correctly using aeroquip cages and tool. Needless to say, I am pretty dissapointed at this outcome.
Not sure what best course of action is short of replacing everything. Was considering applying a poly or epoxy sealant where end of hose meets fitting but not sure if that would work.
Any ideas or similar experience welcomed.
Thanks.
Thanks.
