Ac not as cold when car warms up
Posted: Fri Nov 22, 2019 11:09 pm
by Miggy
Hey guys, i have a new problem with my car ac that just showed up recently. The ac performance decreases as the car warms up.
These are the readings with the gauges i bought:
Car in the garage, cold start:
Vent temp 12.5 degrees celsius (at least according to my cheap digital thermometer)
Low side pressure: 25 psi
High side pressure: 175 psi
Ambient temp is at 25 degrees celsius (at least according to my cheap digital thermometer). The weather app on my phone says 27 degrees celsius.
After driving the car around for awhile:
Vent temp: 16 degrees celsius
Low side: 28 psi
High side: 185 psi
Ambient temp is still at 25 degrees celsius. The weather app on my phone says 27 degrees celsius.
All of the readings at idle speed, max fan speed and in my garage.
The car isnt overheating, both fans are working. The condenser fan motor has been upgraded to a two speed one running at high speed with ac on.
"New" used evaporator, new txv and reciever drier.
Any ideas why this could be happening? Thanks.
Oh, and i also checked the heater blend door, its completely closed with the knob at max cold.
Re: Ac not as cold when car warms up
Posted: Sat Nov 23, 2019 6:04 am
by Dougflas
Clamp off the heater.
Posted: Sat Nov 23, 2019 8:17 am
Miggy wrote:Hey guys, i have a new problem with my car ac that just showed up recently. The ac performance decreases as the car warms up.
I'd like to see both low and high pressures at about 1800 rpm. Idle is not where to test.
Posted: Sat Nov 23, 2019 4:11 pm
by Miggy
Dougflas wrote:Clamp off the heater.
I'd like to but then i wouldnt have a way to control the temp when its cold outside. Its very humid here so it isnt comfortable using the car with ac off, specially when its raining.
Posted: Sat Nov 23, 2019 4:15 pm
by Miggy
Cusser wrote:Miggy wrote:Hey guys, i have a new problem with my car ac that just showed up recently. The ac performance decreases as the car warms up.
Alright, ill get the readings at 1800 rpm. Its quite cold here right now so ill take it when it gets hotter later in the day.
Posted: Sat Nov 23, 2019 4:18 pm
by Miggy
I forgot to mention that the problem appeared a few days after i had my evaporator replaced with a "new used" one. I brought it back to the shop but the ac guy without a thermometer told me the pressures are fine its cold.
The problem also progressively gets worse the longer you run the car. I got stuck in stand still traffic for nearly 30 mins and the cooling was basically non existent.
Edit: And it got cold again when the traffic started moving.
Posted: Sat Nov 23, 2019 4:36 pm
Miggy wrote:The problem also progressively gets worse the longer you run the car. I got stuck in stand still traffic for nearly 30 mins and the cooling was basically non existent.
This seems to indicate a bad fan clutch to me. If your vehicle (you didn't state year, brand, model) has electric radiator/condenser fans, then NEVER MIND!!
Miggy wrote:I forgot to mention that the problem appeared a few days after i had my evaporator replaced with a "new used" one. I brought it back to the shop but the ac guy without a thermometer told me the pressures are fine its cold.
If such evaporator is not exactly the same as the original one, may affect the oz. refrigerant required.
Posted: Sat Nov 23, 2019 4:55 pm
Was the replacement evap surrounded by insulation. sometimes aftermarket cores let air pass by the sides of the core.
Posted: Tue Nov 26, 2019 2:30 am
by Miggy
Cusser wrote:Miggy wrote:The problem also progressively gets worse the longer you run the car. I got stuck in stand still traffic for nearly 30 mins and the cooling was basically non existent.
I have electric fans.
The used evaporator is an original nissan one.
Posted: Tue Nov 26, 2019 2:31 am
by Miggy
Tim wrote:Was the replacement evap surrounded by insulation. sometimes aftermarket cores let air pass by the sides of the core.
Yes, this evaporator has insulation. Funny though that the original evaporator that came with the car didnt have any insulation wrapped around it.
