2015 silverado variable displacement compressor
Posted: Tue Oct 29, 2019 1:52 pm
I just finished an L83 and 6L80E swap into my '63 Pontiac. I am trying to get the A/C working. Everything on the system is off of the truck, compressor. condenser, evaporator and hoses. Obviously I do not have the BCM to control the de-stroking of the compressor so I added a low pressure cutoff and plan to cycle the clutch to control temp. Problem is that I started to charge the system and the low pressure is 75 pounds with 12 oz of R134 in the system which in my mind means that the compressor is de-stroked. My assumption was that the compressor would de-stroke by adding power so I don't have those wires connected. Does the compressor de-stroke by reducing power? If so would I feed 12 v to the de-stroking solenoid to get the compressor to maximum stroke? If not is there another way to disable the de-stroking system.
