2007 Honda Accord - Driver's side *hot*, psngr side ice cold
Posted: Thu Aug 15, 2019 5:37 pm
Hi all, I haven't had any luck figuring out what's wrong with my Accord, hoping someone here can point me in the right direction. I have an 07 Accord EX-L. About a month ago it suddenly starting dumping *hot* air (not ambient temperature) on the driver side while the passenger side blew ice cold (yes, I checked to make sure dual zone wasn’t turned on). Some factors which might set my case apart:
1. The problem went away after about an hour of highway driving. Since then, it's acted up twice, where the hot air suddenly appears and then after some hours or days goes away again.
2. I took the car to a mechanic today, who ran his diagnostics and found nothing wrong -- as luck would have it, the AC was working fine when he turned it on.
3. The climate control system’s temperature setting has always been wonky (I bought the car used four years ago). For a comfortable temperature in the summer the temp needs to be set to about 26C degrees (79F), but the air coming out the vents is much cooler. I replaced the cabin temperature sensor right after buying the car but that didn’t make a difference. I've half-convinced myself this particular problem is caused by some super expensive electronic circuit board that requires taking the entire dash apart.
4. There are no HVAC codes flashing when I run the internal DTC test.
5. No problems with blowing heat on either side with engine running.
I'm wondering if the intermittent nature of the problem helps to narrow down the issue, combined with the fact that apparently the system doesn't have any obvious problems (doesn't need to be charged). I'm starting to wonder if a faulty temperature blend servo on the driver's side might make more sense given the sudden ON/OFF problem - could refrigerant issues cause that? Presumably electric gremlins could. FWIW, this driver hot/passenger cold issue is well documented with Accords from that generation, and the problem most often is that the system is undercharged.
Any thoughts appreciated.
