2009 GMC Arcadia compressor starts and stops
Posted: Thu Aug 01, 2019 8:22 pm
Hello all. Recently had fitted new condenser new fan and pressure switch. Compressor cycles on and off to often. Runs for a few 2nds then stops. Then starts 10 secs later and stops. I have had gauges on it. At ambient temp without running system pressure is about 120 psi. And 40 psi on low side. After car has been sitting for a while and starts up cold i start the compressor and see press changes high side goes up.to near 200psi and low towards 25. But I dont see the condensor fan running.
After this the compressor just cycles on and off around 120 psi every few secs.
If I cycle the ac button in car on and off the compressor does try to start each time but only for a few secs again.
Should the condensor fan run as soon as ac button is pushed ? Or is it run on pressure?. Does condensor fan run at 2 speeds. I have seen it running at its appears slow.to.me.
Does anyone now what set point the HP switch has.i.am.living in miami so ambient is 90F plus.
