Problem with short cycling
Posted: Tue Jul 30, 2019 11:47 am
Hi
I bought a 1996 Geo Tracker with a Sanden SD7B10 compressor. The AC blew cold when it was at idle or moving slowly sometimes but not when moving at 40mph and up. A assumed over or under filled and maybe too much oil from previous owners. I wanted empty it and refill from scratch to make sure I had it right. Then I did something stupid and forgot to empty before removing a Hose! That did make it very empty fast. I removed the compressor and drained it. I found a leaking schrader and replaced it. I replaced the dryer. I drew a vacuum on the system for half of an hour. It calls for 90cc of PAG (or 3 oz) which I put into the compressor and filled the 134 from a 30lb can on a scale. All worked well until I got 1lb 9oz in then the compressor started short cycling. Any idea what would cause this?
