Citroen Dispatch - can't find leak
Posted: Mon Jul 29, 2019 5:52 am
Hi my name is Wayne and I'm having a few problems with my aircon on my van, if anyone can offer me any pointers I would be grateful. This is the sequence of events, we purchased the van about 12 months ago and all last summer the aircon worked perfectly, this year when it got a bit warmer it didn't work at all, I did a few preliminary checks and deduced there wasn't any pressure at all in the system.
I then took it to my local specialist and he did a vac test and a pressure test with nitrogen and it failed them both, all he could tell me was it was leaking somewhere and it could get very expensive to fix. He did suggest the condenser is a likely culprit so I took the vehicle back home and removed the condenser, I then pressure tested it on my bench and checked with soapy water, sure enough it had a small leak in it with the soap bubbling away. I ordered a new condenser and replaced it along with the o-rings for it.
I took it to one of those re-gas places offering a cheap re-fill with a voucher, they said they can't do it because its still leaking. I got them to pressure it up with nitrogen and drove it away. I then bought my own gauge set and vac pump from Amazon to see if I could find anything, checking the pressure with the gauge set it was bang on 90 psi a few days after he charged it up, I checked the next day and the needle was still exactly where it was so as far as I can see there is no leaks in the system. However if I do a vac test the gauge drops to near enough zero within 30 seconds, its not the gauge set because if I close the schrader valve knobs the vacuum holds.
So why would it be rock solid under pressure for days but lose a vacuum straight away? I don't get it, I left the pump running for about 45 minutes as well, it does initially drop down to about -28 on the gauge when you start the pump but as soon as you shut of the manifold valves it drops back down.
Thanks for reading, Wayne.
