1992 Cavalier leaking oil from back of compressor.
Posted: Sun Jul 21, 2019 5:50 pm
I have a 92 Cavalier with the 2.2L which uses the V5 compressor. almost two years ago I replaced the compressor with a new one due to it leaking at the body seal and it had been on the car since about 2007.
Fast forward to about a month ago and I have no air. I check things out and discover that there is a leak at the back of the compressor and it looks like it's coming from where the lines go into the back of the compressor.
Since the system is empty I remove the lines and install new sealing washers. I make sure that the securing bolt is tight. I vacuum the system down for 30 minutes and then let it sit for 30 minutes and the needle on the vacuum gauge does not move. I then vacuum the system down for another 30 minutes and then let it sit again for 30 minutes and the gauge still doesn't move so I was convinced that I had no leak. Since I still have a tank of R12 and that is what was in it, I recharge the system with the correct 36 oz and get 38 degrees from the vents.
Today I run my hand on the back of the compressor just to check and it comes back soaked with oil. The air is still Ice cold. I put the car up on ramps and it looks like it's leaking at the line going into the back of the compressor again. It looks like it's leaking at the upper line which is the cold line. The lines above the connection point all look dry so I don't think the line is cracked and like I said, the air is still ice cold.
I'm pretty frustrated because I don't know how it could be still be leaking and really don't know where to go from here. I'm pretty sure it has the correct sealing washers because they look the same as the ones I just removed and from the ones I kept from the 2007 compressor replacement.
Does anyone have any suggestions? Thanks.
