No A/C after cooling fan melt down
Posted: Wed Jul 03, 2019 11:31 am
Hello, i have a 2005 Acura RL 3.5 V6.
About 2 mouths ago, i was out of town and started hearing this wining turning into a loud kinda griding sound only when the A/C was on, i turned it off and tried again the next day to find no A/C, it never worked at all after that. I get home to find the right cooling fan had literally melted, and fried the ground wire to the frame, which was also tied in with the harness that went to the A/C compressor, took the bumper off, fixed the melted wiring, new fan, turned it on and the clutch on the A/C compressor kicked on but no A/C, took it to a buddy that had one of those nice A/C machines and evacuated the system to find i only had 0.50 charge, he said that was low and charged it 1.05 pounds, but still no A/C, lines are not getting cold. With A/C off, high side is around 100PSI, with the low side being at around 120PSI, with the A/C on, its the same.
At this point, we both figured the compressor went out because of the fan issue, so new compressor installed, same thing, so we replaced the expansion valve and drier filter, still no go.
NOTE, one time when recharging, the low side went over 300PSI, but it only did that one time, not sure what that meant.
Now we're not sure where to turn, compressor clutch is engaging and disengaging when it should, no codes, any ideas what it might be?
