134A Pressure Chart Differences
Posted: Sat Jun 29, 2019 8:12 am
Can someone explain why low side/high side gauge pressure charts vary so much? For example I see charts that show, at 90 degrees, a low side of approx. 30 psi and high side of 225. Another chart will show 50 PSI and 260 PSI? One chart even allows for differences in humidity.
I know engine RPM, airflow, spraying the condenser with water all have an effect on pressures. Bottom line I never know quite what to expect when I hook up a set of gauges to do a test or charge a system.
Thanks!
Thanks!
