Performance not Pressure
Posted: Thu Jun 20, 2019 8:52 pm
Hi, just had new compressor installed for my van's AC and with no book value amount of refrigerant to go by shop said they went "by pressure". Cools well but at hiway speed compressor cycles on about 17 secs then off about 17 secs. The off is very noticeable due to hi (90+) heat outside. I would like to tweak the coolant to cut down that off time. Did it once before from the low side only with very good results but can't remember if I had to add or subtract a little bit to get desired effect. Any ideas would be appreciated. Add or subtract?
