electronically controlled variable displacement
Posted: Thu Jun 06, 2019 10:51 am
I am putting an ls engine and trans out of a '15 Silverado in my '63 Pontiac. I plan to use the compressor, condenser, evaporator and hoses off of the truck because the charge seems to be quite critical with a variable displacement compressor. Is there a compressor that will fit on that engine with a mechanical variable displacement or is there some way to modify the existing compressor to mechanical?
Thanks.
Thanks.
