A6 compressor shaft seal
Posted: Sun Feb 17, 2019 10:56 am
Hi All,
I'm rebuilding a Harrison A6 Compressor from my 75 Corvette. I bought a seal kit that has the newer lip seal. I am confused about how to set the new seal. The old seal was two parts with the ceramic outer ring. The new seal doesn't appear to be the same thickness as the old two piece seal so how does the snap ring hold it into place? Do I still need to use the ceramic outer portion? Also, I didn't take note of where the front o ring sits when I took it apart. There are two grooves in the front shaft casting piece. Does the new seal fit the bottom groove and the snap ring the outer groove or is the lower groove for the o ring? If not I assume the O ring will just get set all the way down in the well?
