Re: 1995 Buick Lesabre
Posted: Fri Jan 13, 2023 1:27 pm
John for the win. There was a Schrader valve under the switch. I discharged and left about 10 psi in the system. Removed the switch and low and behold there is a Schrader valve hissing at me. I took pick pics of the switch to get part a part number. There was an O-ring on the Schrader body which was torn in half. I put an O-ring from a generic kit on and put the switch back on.
Ordered an AC Delco with same part number, it will be here Sunday.
I wanted to leave some residual pressure in the system, in the hopes of not needing to vacuum it down. If I replace that Schrader valve that will empty the system. I’m guessing this will be the last fan switch this car ever sees, so thinking of just installing new switch and let it be.
