Page 6 of 7
Re: gauges leak out freon after use
Posted: Tue Jul 27, 2021 10:03 am
by penguins25
it must not be 134a because the hose connects to the 134a freon tank
Posted: Tue Jul 27, 2021 10:05 am
Is that image of your pump or just something you grabbed off the internet?
Posted: Tue Jul 27, 2021 10:22 am
by penguins25
thats my pic
do you know what size the fitting must be for the santech gauge hose to connect to
example what size thread is on the 134a 30lb freon tank
Posted: Tue Jul 27, 2021 10:59 am
R134a, 1/2" ACME THREAD.
Posted: Tue Jul 27, 2021 1:07 pm
I am so confused, he has his hose obviously connected to the R134 fitting at the top of the TEE.
The R12 fitting on the side is vacant. It should be capped when he is vacuuming. He will never use it.
ie I do not see a problem
Posted: Tue Jul 27, 2021 1:16 pm
As said, the yellow hose fitting for R-134a should readily thread onto the 1/2" ACME port...unless your vacuum pump fitting is the left-hand-thread version that's designed only for R-1234yf. Both adapters look identical at first glance.
Posted: Tue Jul 27, 2021 1:26 pm
tbirdtbird wrote: Tue Jul 27, 2021 1:16 pm
I don't think it's actually connected. I believe the OP is just holding the fitting right above the port of the tee to show that it won't thread on. I agree, though, the picture looks confusing.
Posted: Tue Jul 27, 2021 2:36 pm
In which case he should check the documentation that came with the pump.
If that is the case, surely there is an adapter for that, they have adapters for everything. Or change out the tee in the pump itself.
Maybe that is why he said at first that the hose would not go on either the jug or the pump, then he changed and said it did go on the jug....he switched ends. And close inspection of threads by an experienced person reveals whether they are R or L hand. Honestly he gives very little detail to go on.......leaving us in the deep weeds
Man I knew there was a reason(s) we decided to avoid 1234yf in this shop, a true disaster. I did not know about the reverse fitting......
Posted: Tue Jul 27, 2021 2:46 pm
You're assuming they are trying to attach a hose to the R134a port in that image.
What is the brand and model of the vacuum pump?
Posted: Wed Jul 28, 2021 6:21 am
by penguins25
its a zeny 125+
