Re: 2007 CR-V, troubleshooting help
Posted: Fri Jul 23, 2021 11:21 pm
Ok, update. My best estimate is that I managed to get 2.5-3 oz of oil out. I put the foam tube things on the top and side of the consenser, but there was still a 3/8" gap on the top, and then on the sides, about 3/8" toward the top and increasing to about 1" toward the bottom. Without tearing the bumper and grill completely off, this is the best I could manage to improve air flow at this point.
Data:
I weighed in 18oz freon.
1500 rpm sitting in my garage
85 degrees ambient, 85% humidity
25psi/325psi, no change on either side when I misted the condenser with water.
55 degree vent temp
While driving it around, the temps got down to 40.8 or so and then jumped up real quick to 45, then took about 30 seconds to get back down to 40.8, then back up to 45. I'm guessing this was the TXV doing it's thing. It was 75 degrees driving around at 10:30pm, so it not a good 'real world' test. My daughter did comment that it was blowing noticeably colder than when she drove it to my house a couple hours earlier. I'll check with her after she has a chance to drive it during the day and see how it does.
Thanks again for everyone's help!
Data:
55 degree vent temp
