Re: 1991 Mustang GT w/ R12 - need help
Posted: Fri Sep 23, 2022 12:17 pm
So the car is not a bad as originally thought. I drove it yesterday and at idle I engaged the AC (MAX AC) and slightly raised the rpm and it started to blow slightly cold air, still no where close to be even considered cold. So it has more Freon in it than I thought.
Pulled it in and started to poke around with a HF leak detector and I got some weird results to the point, where I don't trust it (the Tif would not go off on these areas). Spraying soapy water did not net any results either. At this point, it maybe just the schrader valves are leaking and just needs a recharge.
Some videos of me playing around with the HF tool:
https://photos.app.goo.gl/G3GBq1JdR2Bz8jGt6
https://photos.app.goo.gl/bMaM6Nvtwrs2zudq5
https://photos.app.goo.gl/N95s3As4RS4WVjHp7
All this time, I was thinking the front seal was leaking on the 6P148a, but with 62k miles, maybe that's not the culprit here. Below is a link to the pic of the underside of the compressor and I believe all the dirt is being slung by a leaking power steering unit/line.
https://photos.app.goo.gl/8xEX2nCVYBmFayyw6
Thanks!
Thanks!
