Re: condinser too hot
Posted: Sun Sep 04, 2016 8:15 am
I think 18 oz. Consult the service manual or look for a sticker under the hood.
Use of a larger condenser will change these amounts only slightly.
Oil should not be added routinely. When the refrigerant leaks out or is removed by a recovery machine, very little oil typically escapes with it, so the subsequent recharge should be just refrigerant. In order to get rid of oil you need to take the system apart and drain or flush the parts.
