Page 2 of 2
Re: Sanden 706P Question
Posted: Thu Jun 20, 2024 11:02 am
by rafjr64
Yes. I'm sure that's what it is. I was able to get it charged up. It's blowing 45 degrees. I probably overcharged by 3oz. Readings were in line with Vintage Air but I know I added more refrigerant than what is called for. Will drive it today. Connect gauges and take some readings; bleed off if I have to. I am thinking I can recover a couple of ounces into one of the empty 12oz cans I used if I crack the valve slightly....from the low side. Won't cause me to lose too much oil will it?
Posted: Thu Jun 20, 2024 2:06 pm
You did not state under what conditions you are getting 45F, but if that is with an ambient of 85F or thereabouts, Iā€™d leave it alone
Posted: Thu Jun 20, 2024 5:16 pm
by rafjr64
90 degrees ambient
Posted: Thu Jun 20, 2024 5:34 pm
rafjr64 wrote: ā†‘Thu Jun 20, 2024 5:16 pm 90 degrees ambient
Leave it alone. :lol:
Posted: Fri Jun 21, 2024 8:54 am
by rafjr64
I'm still concerned about the accuracy of these gauges and the fact that I installed more than the recommended refrigerant. should prob get my own set of gauges or take it to a shop get their opinion. but I hear you. thank you.
Posted: Fri Jun 21, 2024 8:57 am
rafjr64 wrote: ā†‘Fri Jun 21, 2024 8:54 am I'm still concerned about the accuracy of these gauges and the fact that I installed more than the recommended refrigerant. should prob get my own set of gauges or take it to a shop get their opinion. but I hear you. thank you.
You should have your own gauge set.
These are a good option, and you will also support the forum.
https://autoacforum.com/viewtopic.php?t=14063
