Page 2 of 2
Re: 1991 S10 Issues
Posted: Wed Jun 12, 2024 5:56 am
by philipk1965
UPDATE....
I put in 2 can of freon, pressures good L 32 H 133.
Works great now, Ice cold!
Re: 1991 S10 Issues
Posted: Wed Jun 12, 2024 6:51 am
JohnHere wrote: Thu Jun 06, 2024 10:49 am If the low-side running PSI is approximately in the mid-20s to mid-30s, then the pressure switch on the accumulator should be "closed," or infinite ohms on a multimeter, which would cause the compressor to engage. If a correctly functioning pressure switch senses abnormally low or high pressure, it would "open," disengaging the compressor. So the zero ohms reading that you tested means the switch is "open."
I think JohnHere mixed this up.
"Closed" would be continuity or very few ohms resistance, likely less than 1 ohm.
"Open" would be infinite resistance, no continuity.
philipk1965 wrote: Wed Jun 12, 2024 5:56 am UPDATE....
Good, don't mess with it. By the way, the pressures you posted are semi-worthless without specifying rpm (typical pressures are read at about 2000 rpm) and outside/ambient temperature.
Re: 1991 S10 Issues
Posted: Wed Jun 12, 2024 7:45 am
Cusser wrote: Wed Jun 12, 2024 6:51 am JohnHere wrote: ↑Thu Jun 06, 2024 1:49 pm
Of course! That's what I was trying to say :oops:
Re: 1991 S10 Issues
Posted: Wed Jun 12, 2024 7:58 am
by philipk1965
1800 RPM
Air temp 74 degrees F
relative humidity 54%
