Alright, since I kind of like working on my own cars and the parts arrived (and my mechanics next possible appointment is in 3 months
), I took a look at my engine to see what else I will need before I tear the AC apart. Btw: I noticed the compressor housing looking pretty dirty, also the belt tensioner has greasy dirt on it next to the AC pulley, also the coolant expansion tank. Maybe this is exactly the problem, the compressor is slowly loosing oil and now is going bad.
Original plan was:
-flush evap, condenser and lines
-replace compressor and orifice tube
-install the correct amount of oil (6oz) along with new o-rings
-install new accumulator as last step to avoid it collecting all the moisture from the air
-vacuum down the system to check for leaks
-if leakfree, leave the system under vacuum until I can get it charged
However, before I even started I took the vacuum pump and gauge set and played with them to get familiar with them since I never used those tools. With the gauge set hanging, not connected to the car, the needle only gets down to 24, maybe 25 inhg vacuum. After closing the valves and shutting the pump off, the vacuum does not drop. So the hoses and gauges seem not to leak. If I only turn the pump off, leaving the valves open, the vacuum still does not drop, so the connection to the pump does not leak as well.
So either the gauges are reading wrong, or the pump is junk. Altitude above sea level is 820feet.
It is hard to get good tools here since literally no one is doing his own work on AC systems. There are vacuum pumps for 100 bucks, 20 different brands but they all look like the same Chinese unit, and then there are pumps for 700 or more, for professional use. I guess I just bought shit, but I really donˋt want to buy equipment for 1000 bucks if I can’t even charge systems on my own in the future since we cannot buy refrigerant here. It’s only for leakcheck and putting a vacuum on the system to keep the accumulator from getting saturated.
So what are my choices now..
Wait 3 months and let the mechanic do everything, then the summer is over and weather is getting bad, car goes into storage.
I would rather repair the system and enjoy it for the rest of the summer. But I need some advise on how to do that.
Given the fact that I can not evacuate the system properly, what would I do after the flushing? I can push the fluid out with shop air and hope the rest will evaporate. Will it? I think so…I dropped a bit of the flush solvent on the floor and could watch it evaporate very quick.
But what about the accumulator..after installing it, how much time do I have to get the system evacuated?
Plan is to finish the system without the accumulator and install it on the day of the appointment with the AC shop just before driving there.
What are your suggestions in that case?
Thanks a lot!
