Re: New Ac system acting up - need advice
Posted: Fri Sep 22, 2023 6:19 pm
First, check your Manifold Gauge Set and/or RRR machine, as well as the hoses, to verify no equipment leaks.
At 86°F with a full charge and good condensing, the high side should be around 200 to 220 PSI. Since yours is an aftermarket system, chances are that the specs aren't the same as those for a factory-installed system.
It sounds to me like it's still a bit low on refrigerant. The following procedure has been discussed a few time on this Forum. But to summarize, try adding an ounce at a time while monitoring the pressures and center vent temperature. After adding refrigerant, let the system stabilize for a couple of minutes with the compressor engaged and the engine running at about 1,800 RPM. Then check the gauges and thermometer. You should see the vent temperature start to drop. If the pressures are still rather low, continue adding refrigerant one ounce at a time until the pressures rise into the desired range and the vent temperature begins rising a little, too. At that point, you've reached the approximate optimum charge.
If desired, recover the system, and the RRR machine will tell you exactly how much refrigerant came out. That will be your refrigerant amount, or specification, for next time.
