Page 2 of 2
Re: System on Fire Engine
Posted: Mon Jul 11, 2022 5:11 pm
I guess the question is, how is the cooling capacity with 47f air? Large volumes of 47f air can cool pretty well.
I would wonder if the TXV has a poor CV match for the Evaporator size, causing the low discharge pressure, but I have a sample size of one here. No like I can compare the system to another - like we would with a Suburban for instance.
Posted: Mon Jul 11, 2022 5:42 pm
by DetroitAC
Dgreen wrote: Sun Jul 10, 2022 3:42 pm 14 on the low side, 225 on the high side, vent temp was 47.
How much hose/pipes between the evaporator and the port where you get this pressure? I saw TM31, suction line should probably be dash 16 sized hoses and maybe 7/8" or larger hard lines?
Posted: Tue Jul 12, 2022 3:47 am
by Dgreen
The system moves a lot of air and at 47 vent temp, it does a good job of keeping us cool.
Connections for the gauges are on the compressor. I would call it a long run of hose from there to the evaporator. It’s a cab over and the evaporator is mounted to the roof on the inside of the cab.
Posted: Tue Jul 12, 2022 6:10 am
by DetroitAC
There you go then, big suction line pressure drop is how you get 14 psi at the compressor but evaporator running reasonable.
Posted: Wed Jul 13, 2022 2:50 am
by Dgreen
Thanks for helping me understand that!
Learn something every day!
