Re: R134a Capacity
Posted: Sat Jul 23, 2022 7:59 pm
I did not record the pressures to be honest. The 53 degrees was at idle. I need to take it on the freeway and see what it puts out while driving.
https://mail.autoacforum.com/
Testing at idle doesn't give useful information because the compressor isn't generating much pressure. However, you can check the pressures and center vent temperatures while the vehicle is stationary: Engine at 1,800 RPM, A/C set to "recirc," blower on high, doors and windows open, and the fan(s) should be roaring. Also note the ambient temperature a couple of feet in front of the grille. Record the pressures while the compressor is engaged and not when it cycles off. A run on the freeway will be a good barometer of actual performance.m240b wrote: Sat Jul 23, 2022 7:59 pm I did not record the pressures to be honest. The 53 degrees was at idle. I need to take it on the freeway and see what it puts out while driving.
