Page 2 of 7
Re: gauges leak out freon after use
Posted: Tue Jul 20, 2021 1:51 pm
by penguins25
i switched the low and high hoses with adapters and the low side of manifold leaked again
i took the manifold back peice off and didnt see any seals so i put it back together and ordered a new pair of gauges
i put the hoses back on the correct sides and pulled another vacuum
now the low side is holding and the high side is leaking
also i noticed the low side needle doesnt pull all the way down to 30 however the high side does
so i dont know it its the gauges or vacuum pump
im going get the fitting seals from napa
im also going to pull a vacuum on my new gauges when they come in
i got the cheap gauges there like 60.00 but worked good in the past
Posted: Tue Jul 20, 2021 2:25 pm
Inexpensive tools that do not work are the most expensive of all
These are the hose seals
- 41ufhLQ7MLL._AC_SX450_.jpg (12.68 KiB) Viewed 8280 times
Tim the forum owner has very competitive prices on quality products, he has a nice manifold, too bad u already ordered from somewhere else
Is your pump electric or compressed air powered
Posted: Tue Jul 20, 2021 4:14 pm
by penguins25
just took one of the seals out and it pancaked at the top and its hard almost like plastic
i think it might be the problem
Posted: Tue Jul 20, 2021 4:16 pm
by penguins25
i got a cheap vacuum pump as well
it stalls if you start it under vacuum
but it pulls a vacuum
i was thinking about getting a quality pump and gauge set but all the other ones on ebay look cheap as well
Posted: Tue Jul 20, 2021 4:27 pm
Is the pump electric?
Doesn't sound like it can pull much of a vacuum.
A vacuum pump will last you a lifetime, why not get something decent? No doubt you will be doing more AC work in your future years.
I have news for you, the experts on here are not getting their tools on eBay.
Again a cheap tool that does not do what it is supposed to is actually the most expensive of all
Posted: Tue Jul 20, 2021 4:32 pm
by penguins25
the seal is not 1/4'' like i see on napa
its an off size .301'' but the hose is 1/4'' i think
Posted: Tue Jul 20, 2021 4:33 pm
by penguins25
i can send the guages back and get some good ones
Posted: Tue Jul 20, 2021 4:50 pm
Post a pic.
You might have 1/2" acme ends
Posted: Tue Jul 20, 2021 5:34 pm
by penguins25
i took a pic but its saying its too big
i tried compressing cutting and still nothing
Posted: Tue Jul 20, 2021 5:40 pm
reduce the resolution on your camera
